Will a NEst be compatible with my current system? I dont see info about wires on the right side
bpjoneser
i have wires on the left (all labeled G, W1, Y1, C, RH) but there are another set of wires on the right named:  Remote Sensor Module, Comm. and Remote Temp Sensor.  WIll the NEST work with mine?  (I want to install myself)
Hello bpjoneser,
It looks like you have a dual set of wires, with one set labeled G, W1, Y1, C, and RH on the left and another set on the right named Remote Sensor Module, Comm., and Remote Temp Sensor. The Nest Thermostat generally works well with a variety of HVAC systems, but it's important to ensure compatibility.
For the wires on the left (G, W1, Y1, C, RH), these are standard HVAC control wires. The Nest Thermostat should be compatible with these. However, the wires on the right (Remote Sensor Module, Comm., and Remote Temp Sensor) are not standard thermostat wires. They seem to be related to a remote sensor system. Before proceeding with the installation, can you share with us a photo of your existing thermostat's wiring configuration?
Feel free to reach out if you have more specific details or questions about your setup. I'll look forward to your response.
