Will nest power connector work with my furnace?
Woohoo
Have tried connecting a nest power connector to get the thermostat working, but there is no obvious place to connect the c wire (heating only setup).  Tried with terminating c wire on connector, but there’s no power at thermostat. Also says r w wiring issues.
Control panel (icm 1530)  has r and w to thermostat and two yellow wires to the furnace ( to the c554a flame sensor).
is it possible to connect a nest to this furnace?
Hi Woohoo,
I'm sorry for the late reply. Thanks for taking the time to talk about your system and how the Nest Power Connector can help provide constant power to your thermostat.
Here are some references to help you install your new Nest Power Connector on your HVAC system.
If you need help from a professional installer, you can schedule an appointment and get pricing from OnTech, our pro installation partner.
If there’s anything else I can help you with, please let me know.
Hello there,
Mel
