Wire a nest power connector with just heat
tsouch
Wire a nest power connector two wires heat only keeps showing no power
@tsouch
Which thermostat do you have?
Can you post a picture of the original thermostat's wiring?
What type of heater/furnace/boiler do you have?
Good chance you will need the Best Power connector and an external 24 VAC transformer.
Wiring is simple, depending on the devices you have.
tsouch
I have an efm coal oil combo it only has two terminals to thermostat where ca you purchase a transformer
@tsouch
I found the best place to purchase a transformer is Amazon
