Wireless Honeywell THM5320R system to the Learning Thermostat?
Jrzydvl
I have a wireless thermostat that connects with a Honeywell THM5320R unit on my gas Air Handler, will the new Learning Thermostat I just bought hook up to it or do I have to hard wire it?
sarahl
I am in the same boat- did you find a solution?
NL2505
I have the same issue , how come google I’ve not find a solution for this ?
Kamull61
Anyone?
sarahl
We ended up buying a nest sensor to put in the main room and hooked the main thermostat on the furnace in the basement. Then; set up the sensor to only change temp based off the sensor. That has worked well
Grogie
Can you share some details of your setup.  Connections?  Thanks
