01-23-2022 08:38 PM
My nest told me I needed the Google power adapter to get it to function properly, however my control board has none of the se letters that I've been seeing everywhere. The terminals I have are T1, T2, F1, F2, A, A. I'll attach a picture of the board. I've tried running the "c" wire back on to one of the T connections (where the red and white are connected as they were previously) but I got a no power error. I also tried connecting it to one of the F terminals and it acted the same as if I hadn't added the adapter at all.
Can anyone help me out? I really can't afford to pay who knows how much for a specialist to connect a wire for me.
Thanks in advance
01-24-2022 06:47 AM
Diagram of the control board from the manual if this helps:
02-12-2022 05:14 AM
I just found this- the “pro” installation manual for the google nest power connector. On pages ############ it shows how to use a separate 24v transformer if the hvac system has no C wire.
https://storage.googleapis.com/support-kms-prod/k5rpNEXV1F0aVYhr8jN1L2GAxhcAPDXhk39r
02-12-2022 05:15 AM
That’s pages ten through eleven
06-07-2022 10:42 AM
Hope this helps!
Kind regards,
Ryan
02-12-2022 03:53 AM
I have a similar carline burner. We’re you able to figure this out? I was going to try the nest power connector.
