Yellow light and no display
B0yHowdy
My nest thermostat battery was not holding a charge and I recently changed the battery in it. Now I have a yellow light (almost appears as it's "pulsing") at the top of the thermostat and no display. I can hook it up to power through usb and have rebooted several times and the displays tells me to connect it back to the mount. When I do, the yellow light just stays on with no display. When Connected via the USB, the green light comes on  and blinks.
Before all this the thermostat worked fine until the battery would not hold charge.
I've also turned the power off and back on to the furnace, to no avail.
Now what???
B0yHowdy
I've learned that if your 3rd generation E learning Google Nest thermostat begins to have battery issues, you can change the battery, but don't. Even if it tells you to check the battery, don't. I was a little disappointed that I only got about 3 years out of this thermostat and would have liked to gotten a couple more years given the amount of money spent.  I took the time and patience and the cost to replace the battery, only to "brick" the thermostat and make it unusable.
I was hoping to get at least a couple more years out of this purchase, and then buy the latest and greatest; kind of like when you buy a new phone. It appears that with the battery life in these are kind of made to be disposable.
Anyway,
c'est la vie
@B0yHowdy
Bummer to hear you bricked your thermostat.
I am going to guess that you didn't have a C wire installed. Am I correct?
@Patrick_Caezza
Have a C wire installed. Is it common for the thermostat to act like it's powering up and when connected through the USB power and the green charging light blinks?
@B0yHowdy
The Nest Learning Thermostat, 3rd Gen does not have a field replaceable battery. The batteries being sold as replacements are the wrong size and can damage your thermostat.
B0yHowdy
@Patrick_Caezza
Seems like it boots up fine via the USB. Then instructs me to add it to the mount.
Then nothing....
