connecting two Nutone Model KB-10 to nest
b78772
I have two existing Nutone’s Model KB-10 door bell chimes hooked up in parallel.  They have worked fine since 1995 with the existing transformer which has a rated output of 16 volts 20va.  I wired the Nest per the below diagram and installed a new HVAC 120/208/240-Volt (Primary) 24-Volt (Secondary) 40VA Rating Transformer.  I cannot get the second door bell to ring.  What do I do now to get the second chime to work?
2 REPLIES 2
TJH501
You should re-post this in the Doorbell section.
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
