easy manual temperature for hot and cold
Jbulldog
 Google Nest Thermostat - Smart Thermostat for Home - Programmable Wifi Thermostat
How do you make the manual adjustment so when changing to a higher temp turns on heat and to a lower temperature turns on cooling?
Jhonleanmel
Hi Jbulldog,
Thanks for posting.
You can turn the ring on your Nest Thermostat's display to get to your desired temperature. Check this guide to learn more.
Mel
EmersonB
@Jbulldog it's us again. I'm bumping up this thread to ensure that everything is covered here. Aside from what Mel has shared, you may also hit this link for more information. Keep us posted.
Thanks for answering, Mel.
Hello Jbulldog,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
