gas burner doesn't light
Jay77
New install, gas forced hot air: info shows electric, forced hot air. Fan runs, gas burner doesn't light. Photo of old thermostat shown.
 Note jumper at red to RC...
Hello Jay, you need to go into System and make a change.  You need to go to the nest thermostat and tap the screen to wake it up. Rotate the dial until you  get to EQUIPMENT and press the outer ring. It will display the equipment configuration tap CONTINUE.  This will open equipment settings, and select HEAT TYPE. Now it will ask you for what type of fuel you use for your heating, your choices will be gas, electric, oil, propane, geothermal if all else fails you can choose I don’t know lol. Rotate to dial to select your type of fuel, in your case GAS and tap the screen, and then it will ask you for the type of heating do you have, forced air, in floor, radiators etc. in your case select FORCED AIR and tap.
The display will to done tap DONE and you’re done.
I hope this helps.
Ken, The AC Cooling Wizard
EdwardT
@CoolingWizard, thanks for the help!
@Jay77, thanks for reaching out. How's it going with your Nest Thermostat? Were you able to follow the steps provided by Ken? Let us know if you have questions and we'd be glad to assist you.
Edward
Jhonleanmel
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
