04-05-2022 10:56 PM
Since I came back from holiday the hot water is not turning on. The schedule hasn't changed and the heating is working as normal but every morning I have to boost the hot water although it should be on for about 30 mminutes before I wake up
04-08-2022 07:41 AM
Hey @SarahTaylor,
Thank you for reaching out. I'm sorry to hear about this, but I'll help you fix it. Just to clarify:
04-09-2022 12:57 AM
The thermostat does not turn the hot water on following the schedule. The boost system works fine. The heating schedule also works. I have not tried manual mode and have not received any error codes
04-09-2022 03:48 AM
Thanks for letting us know, @SarahTaylor.
Could you tell me please if the Bacteria prevention feature is on? Please go into Settings > Equipment > Continue > Bacteria prevention and let me know. If it's on, please turn it off and monitor it for 48 hours.
04-09-2022 04:23 AM
It was but I turned it off a few days ago and it has not solved the problem
04-09-2022 04:49 AM
Understood. Could you tell me please when did the situation start occurring at first and when was the thermostat installed?
04-09-2022 05:06 AM
This started when we got back from holiday 2 weeks ago and the Nest was set to the Away mode. We have had the thermostat a few years.
04-09-2022 05:23 AM
Thank you. Could you tell us please if you had any type of power cuts or maintenance work to the heating system?
04-09-2022 06:02 AM
No
04-09-2022 06:31 AM
Got it. In this case, please go in front of the Heat Link with the Nest app, then please boost the hot water and tell us please if you can hear a click coming from the Heat Link? Same for turning it off.
04-09-2022 06:55 AM
What is the heat link
04-09-2022 06:56 AM
but there is no click when I boost or turn off the hot water
04-09-2022 07:05 AM
The Heat Link is the white square box that's usually next to the boiler. It should have a green light on it. That's the one that should click, not the thermostat.
04-15-2022 08:23 AM
Hi @SarahTaylor. Just checking in, did you manage to check the last message from my colleague?
04-18-2022 04:55 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
