how to wire Nest thermostat to combined AC plus Gas heat air handler
FuzzyH
I have ac plus gas heat, I have B/C wire on old thermostat, do I enter it as B or C? I wired to to Nest C and the AC is working but I am concerned that Nest tells me I have a Heat Pump which is incorrect.  It is only AC cooling.
3 Recommended AnswerS
ctcomsa
Hey Fuzzy what do you mean when you say nest is telling me heat pump . you can change the info later just for the heat section choose forced air and it will work fine.
Curtis
FuzzyH
Thanks I actually figured this out but did not know how to retract my question.  Thanks for your effort!
FuzzyH
I have solved trouble with my new programmable Nest thermostat which included occasional power Error codes. After several attempts to reprogram, I finally discovered that I had TWO breakers in my electrical panel - 1 for the AC and another for the Air Handler.
I uninstalled and reset the thermostat, this time I turned off BOTH breakers and reinstalled the thermostat from scratch. NO more error codes and everything works well since.
Hoping this saves someone else a few hours of frustration.
7 REPLIES 7
ctcomsa
Curtis
FuzzyH
MelbaDT
Thanks for answering, ctcomsa.
FuzzyH, glad to hear that you've figured out the answer to your own question. Feel free to let us know if you have more in mind.
Melba
FuzzyH
ctcomsa
Awesome I'm just glad you got it working properly. 😀 i'm sure it will help someone!
Curtis
MelbaDT
I appreciate your time sharing what you've done to have your concern resolved. I'm glad to hear that you've got it sorted out.
Thanks as well for chiming in, ctcomsa.
Feel free to let us know if you have further questions in mind.
Melba
MelbaDT
Melba
