need help for nest thermostat
Nikhildesai
hi
i have Nest thermostat. I recently upgrade my A/C from straight cool to heat pump with 5kw heat element.  I need wiring connection diagram for Nest thermostat.
Hi Nikhildesai,
Thanks for reaching out. I'm sorry for the delay. Could you please share with us the photo of your thermostat wiring? It will help us to check its wiring configuration.
zoeuvre
Hello Nikhildesai,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
I appreciate your help here, Jenelyn.
