12-17-2022 07:56 PM
I updated my router recently and haven't been able to get my Nest thermostat to connect reliably. 20+ other devices are connecting, so I'm confident that connectivity is good. Old and new router were both TP-Link.
Right now, I can get the nest to connect to my router. However, based on one of the articles, I logged out of the app and logged back in. When I go to reconnect the app by getting a new secure entry key, it fails to connect and give me a key. Also, ping time on the nest is 0. I've had this work sporadically since getting the new router; once I had to do a hard reset of the nest. Now I'm just frustrated with it.
12-21-2022 12:35 PM
Hi AJD,
Thanks for posting.
A quick question: after factory resetting your Nest Learning Thermostat and setting it up again, are you getting a message that's preventing you to move forward with the setup?
Mel
12-21-2022 02:22 PM
I did previously reset it. Initially, after installing the new router, I couldn't connect via Wifi at all. I did a reset and things worked for a couple weeks.
12-22-2022 09:21 AM
Hi AJD,
Thanks for getting back to us. To confirm, your Nest Learning Thermostat is dropping from your new router, right?
Mel
12-23-2022 05:15 PM
Mei - it started working again. I can access the thermostat using the iOS app. I'm not sure what happened, but nothing else to do.
Thanks.
12-23-2022 05:28 PM
Hi AJD,
Thanks for the update. I'm glad to hear that it's working fine now. Please observe it for now and let us know if anything comes up.
Edward
12-26-2022 05:33 PM
Hi AJD,
Edward
12-27-2022 07:56 PM
Hi AJD,
Edward
