10-03-2022 08:11 AM - edited 10-03-2022 08:16 AM
Hello I can't quite figure out how to wire from CT87N1001 THE ROUND® WHITE HEAT AND COOL THERMOSTAT - FAHRENHEIT SCALE to Nest Learning Thermostat.
These are the wires that I have.
Is this compatible with Nest?
Thank you so much in advance.
10-03-2022 08:14 AM
I forgot to mention that I have a gas furnace with hot water baseboard heater and Central AC.
10-03-2022 08:56 PM
Do you have a picture of the original thermostat with the wires still attached to the base plate?
10-04-2022 06:22 AM
Yes.
Thank you so much for your help.
10-07-2022 02:07 PM
@Patrick_Caezza, thanks for the help!
@Deukki88, thanks for posting the photos of your current thermostat. I'm a bit confused with the wiring of your current wiring and the type of HVAC system that you have. Could you also share a photo of the control board of your HVAC?
Edward
10-12-2022 07:18 AM
I appreciate the help, Edward.
Archie
10-12-2022 07:11 PM
Hello Edward,
Sorry for the late reply.
I just came back from a work trip.
I will get that information and uploaded by tomorrow.
Thanks!
10-13-2022 09:44 AM
Hi Deukki88,
Thanks for the response. Keep us posted.
Edward
10-16-2022 11:03 AM
Archie
10-17-2022 11:30 AM
Archie
