02-10-2024 04:02 AM
Hi
My 2.4 ghz devices drop connection to my Google Nest Wifi Pro occasionally. When the network restarts, the problem is solved for a while then they get disconnected again.
I found multiple users complaining about the same issue. I tried the suggestions I found including identifying DNS and factory resetting the system. Nothing seems to work.
i hope there is an actual solution for this problem. I don’t want to have to replace Google WiFi with another system.
regards,
