Problem when adding a Nest Wifi-point
andypanda19
I have just factory reset my Nest Wifi Router and its running wifi OK. So far so good.
The problem starts when I try to add a Nest Point.
To add my Nest Point I open up the Google Home app on my iOS device. I add the device, scan the QR code and it starts setting up a Mesh Network but it fails with the message:
"Handlingen kunne ikke fullfores. (googlemac_iPhone_Home_Wifi
_Operations_Impl_Impl.PollForC ompletionOperationImpl-feil 0)"
I have tried many times. Moved it closer to the Router. Deleted the app, reset the Router and the Point many times...
Any ideas what it could be?
David_K
As you're using an iOS device for setup, I'd recommend checking these steps:
Troubleshoot setup with iOS - Google Nest Help
