04-15-2023 11:15 AM
Where do find if my google wifi has 2.5k available for devices (a smoker) that require it to link to a smart phone (S-22)?
04-20-2023 10:24 AM
Hey KCOC,
If you're referring to the 2.4GHz band, then yes, Google WiFi supports that wireless standard. Google and Nest WiFi support the 2.4GHz and 5GHZ bands simultaneously (and Nest WiFi Pro adds 6GHz too). Devices that need either of those bands will be able to connect to your Google WiFi setup. If you have any other questions, just let me know.
Jeff
04-20-2023 03:07 PM
Hey Jeff.,
Thank you so much for the answer
Ksey
04-20-2023 03:16 PM
No problem, KCOC.
Just to follow up, did you have any other questions or anything else I could help with?
Jeff
04-20-2023 05:04 PM
I was wondering where you find it. I had an issue one time witha product and the guy from another country told me I needed to get into my wifi and assign 2.4 hz to this product and make sure it wasnt 5.0.. Is there a way to get to that from my app or somewhere I can see it..
04-22-2023 03:50 PM - edited 04-25-2023 03:48 PM
@KCOC, your Google Wifi router and points use the same name for both the 2.4 GHz and 5 GHz band networks. This means that the Wi-Fi network uses both radio bands. But keep in mind: while both bands can be used, the personal devices (a smartphone, tablet, laptop, etc.) will connect to only one radio band at any given time. Nest Wifi, Google Wifi, or Nest Wifi Pro attempts to select the band that will deliver the best performance for your device. Currently there is no option to manually disable either of the bands or to connect to them separately.
Give these steps a whirl:
Create a hotspot with a mobile phone. Take note that 2 mobile phones are required. Use the first device to create a hotspot (mobile phone). How to set up a mobile hotspot:
Android
iOS
Once done with the first mobile device’s hotspot:
Let us know how it goes.
Thanks for the help, @Jeff.
Abi
04-24-2023 11:17 AM - edited 04-24-2023 11:18 AM
What i had to do with a device that would only connect via 2.4 was i had to go out the the edge of my wifi (like out in the road) and reconnect to wifi to access the 2.4 signal because apparently it goes out farther then the 5. It took me forever to findnout how to do this. Hope it helps
04-24-2023 02:26 PM
Thank you for the reply. I had issues with a security system cameras and the help line was in Thialand or somewhere (heard roosters in the background), and thats what he was saying but because of the heavy accent it took a few tries to get what he was saying. ):(.. Apparently Google is auto connect with whatever the system needs.
04-25-2023 03:52 PM
Hello folks,
Thanks for sharing the steps that helped you, @Alyoop25.
@KCOC, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Appreciate you lending a hand here, @Jeff.
Abi
04-25-2023 08:44 PM
Thank you Abi,
I don't have two phones so couldn't try it, but I did print your guidance off and saved it too files as well
Thank you again KCOC
04-29-2023 03:16 PM
Hey KCOC,
Thanks for the update. Checking back in should you still have other questions here. Let us know by replying to this thread.
Abi
05-02-2023 11:41 PM
I'm just checking in to see if you still need assistance with this. Let us know if you have additional questions ― we'd love to help.
Abi
05-03-2023 11:54 PM
Abi
