08-24-2022 08:02 AM
I’m sure this has been asked and answered. But I’ll go with it anyway. (Also, I have finally been surpassed with technology and am turning into a grumpy old man that can’t figure out the remotes to TV’s 🤣)
First, from what I am reading, there is a difference between a google WiFi point and a google nest point. Is that correct?
my problem. I have an existing mesh with 1 router and 2 “access points?” All are “google WiFi”. I have bought a 3rd “google WiFi” to add to the mesh system.
However, I absolutely cannot get it to connect to the existing mesh.
The access point skips right to the option of setting up as a new network. Ie, I do the steps:
Add device
Connect to home.
Searching and finds the SB1234 and asks if I want to join that network instead of my existing network. From there, I can get through a few more screens before it fails. (which makes sense because it is acting as it’s own WiFi point and it isn’t physically connected to anything)
I will say a couple of things:
I have factory reset and get a flashing blue when trying to connect
I have also seen some advice about getting it from the same country? I only know that it was probably made for Europe because it came with an American plug adapter.
Is there anything I can do or should I just return it?
thanks!!
08-24-2022 11:45 PM
Here are info on the three different models:
Here are info on combining them:
And yes, combining pucks from different regions/ countries won't work, this is likely due to differences in Wi-Fi regulations. Mentioned here:
08-29-2022 05:15 PM
@olavrb, thanks for the help!
@Briank122310, how's it going? Were you able to check the links that olavrb provided? Keep us posted.
Edward
08-31-2022 05:16 PM
Hi Briank122310,
Edward
09-01-2022 05:53 PM
Hi Briank122310,
Edward
09-01-2022 07:29 PM
Hello! Thank you kindly for the responses!
As it turned out, the unit I ordered from Amazon was for Europe with an adapter to US.
I ended up returning that one and ordering one for the US (1200 Model) it connected to the existing mesh system on the first go.
Thank you so much again!
09-01-2022 07:40 PM
Hi Briank122310,
Thanks for the update. I'm glad to hear that you were able to figure it out. I will be locking this thread in 24 hours. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
