ClearNode AllStar Node Amateur Radio
PEZoba
I have Comcast internet with a NetGear CM 1200 cable modem. This connects into Google Mesh wifi router.
I am trying to connect a ClearNode AllStar node which needs ports 5198 and 5199 forwarded in both directions.
I have forwarded external ports 5198 and 5199 to confirm internal port 5198 & 5199 UDP and set the node to a reserved IP address (static) but I continue to fail the firewall test.
any help?
Jeff
Hi, PEZoba.
Sorry about the late reply here and for the issues you're seeing with your port forwarding efforts. I imagine that's quite frustrating. We have a help article for port forwarding, which you can see here: https://bit.ly/2VFhZ5S.
If you're setting everything up as mentioned in the article and you're still seeing issues, please let me know and we can look at more specific causes.
Thanks.
EdwardT
@Jeffrey, thanks for the help!
@PEZoba, how's it going with your Google Wifi? Still need our help?
Edward
PEZoba
No, thanks. I removed the Google WiFi and installed an Eero system. All is working now.
EdwardT
Hi PEZoba,
We're sorry to see you go. We're always here if ever you change your mind.  Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
