11-22-2023 11:00 AM
I'm not actually sure which device I have. It's not the first generation wifi it's the annoying one that has Google assistant built in that you can't turn off.
Anyways, I just got a new ISP hooked up today. When I connect to the modem/router directly I get 100Mbps down and up.
When I connect to the Google WiFi I get 100 down and only 20up
11-27-2023 11:41 AM
Hi JamesWelbes,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Which Google/Nest router are we working with? What device are you using to set up your network (iOS or Android)? Do you have the Internet on your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
