01-22-2022 11:54 AM - edited 01-24-2022 05:56 AM
Apologies if this is already covered: searching keyword "ethernet" didn't turn up a similar issue.
So here's my situation:
Until about a month ago (?) the router + 2-mesh point setup below was working fine with all wired devices happily getting internet through their wired connections. What tipped me to a problem was when devices such as my TV and AV receiver, which can only be connected by ethernet, stopped being accessible through their apps (I confirmed in the Google Home app that they're no longer on the network at all).
So here's my router + 2 mesh point setup:
modem ➡️ Google Wifi AC100 puck configured as router ➡️ 40 ft. ethernet cable ➡️ 8-port TP-Link switch ➡️ short ethernet cables to assorted entertainment devices 📺📻🎮
TP-Link Google OnHub mesh point ➡️ 5-port TP-Link switch ➡️ 2 desktop PCs 🖥🖥
TP-Link Google OnHub mesh point ➡️ Lenovo dock ➡️ 1 laptop computer 💻
What I've done
So it seems like there's an advanced setting in the Google Wifi router that needs to be set to allow devices to connect through a switch. I just don't know what that might be.
01-23-2022 04:55 PM
I don't think I have a solution, sorry...but did want to mention I do the exact same thing with my Nest Wifi Router. I run an ethernet cable out to an 8-port Tenda (SG108) switch, then run cables to a heap of my entertainment equipment. I also run a cable from the 8-port Tenda into a wall point that then runs up to the other end of my house, where I have a 5-port Tenda switch that feeds my main PC and a couple other wired devices. It's all been working ok for a couple of years now.
So what you're doing is obviously correct, but something's broken somewhere. I don't know anything about OnHub, but I heard late last year that Google was dropping support for them in 2022.
01-24-2022 05:55 AM
Yeah, the OnHub news is why I moved things around to make them just mesh points, rather than relying on one as a router (they'll keep working, but won't get updates--so I put them where they'll least need to be updated). Ironically, ethernet connected to the OnHubs works perfectly. It's the Google Wifi puck that's misbehaving.
01-24-2022 04:13 PM
This one is frustrating me. The fact your hardwired ethernet device works when plugged directly into the Nest wifi router, but not when the router runs to your switch first is really strange. The TP-Link switches are definitely 'dumb' switches yeah, not devices with a WAN and multiple LAN ports?
01-25-2022 12:38 PM
That's right. Totally dumb switches that were 100% plug and play for over a year (and still are when connected to a mesh point).
02-04-2022 07:17 AM
An update: it works now. I can't tell you why. Possibly power-cycling with all ethernet cables unplugged, then reconnecting them in some specific sequence was finally agreeable to the router. So all I can say to others with this problem is, don't lose hope!
02-04-2022 07:52 PM - edited 02-04-2022 07:52 PM
Good to know, that was annoying me given there was no reason it shouldn't work! Glad you reported back.
03-18-2022 09:39 AM
Hi, nrmaharaj.
Thanks for letting us know what worked for you. It's been a while since this was wrapped up, so I thought I would check in and see if anyone needs anything else or if we're good to mark this as resolved. If anyone needs anything else, just let me know.
Thanks.
03-22-2022 11:25 AM
Hi, everyone.
Thanks.
03-23-2022 02:13 PM
Hi, everyone.
Thanks
