Extending a Nest Wifi Mesh with a wired connection
MrJM
I already have a Nest Wifi router and nest point (the one with the speaker). But the point is too far from the router and basically I need something in between. So two questions:
1. Can I get a new nest wifi router and add it as a point to the existing mesh?
2. Can I connect that new nest wifi router with the main router via a cable (cat6) and still have it part of the same wifi setup? that would avoid using wireless between the points and should hopefully improve the connectivity.
Any other thoughts?
6 REPLIES 6
olavrb
Yes you can, see the reply I just wrote you here:
I don't work for Google.
MichaelP
Hello @MrJM
I just want to add one clarification – yes, you can add a wired Nest WiFi Router (or a cheaper Google WiFi unit) to your existing Nest WiFi network to expand the coverage area. However, it will not be extending the mesh network itself. Meaning, a distant wireless Nest WiFi Point unit will not connect through the new wired secondary Nest WiFi Router. But, having the new wired secondary may provide enough coverage to clients in that area that the Nest WiFi Point unit is no longer needed.
MrJM
Thank you both. I ended up not wiring, and the new router is setup as a point in between, I am still a bit puzzled as to why some devices stays on the original point instead of the new router, but it is overall far more reliable. I think the initial point is connected to the new router/point, but I can't find a way to confirm other than, well, it works way better than before.
JM
AbigailF
Thanks for lending a hand, @MichaelP and @olavrb.
@MrJM, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
AbigailF
Hi MrJM,
Abi
AbigailF
Hello everyone,
Abi
