05-10-2023 10:40 PM
Hi. I have FTTP connected to my property and use the Google Wifi Nest and it is showing as 5ghz only. I use swan cameras and the SOFAR app for my solar inverter and they require a 2.4GHZ connection. I have tried setting up a guest network but this does not work. is there a work around or a way I can get my modem to create a 2.4ghz network?
Thank you
05-11-2023 12:56 AM
Hi @Ourdarwin10
Nest WiFi uses 5GHz and 2.4GHz at the same time.
It is up to the device to connect its supported network.
So there is a 2.4GHz network available but without a separate SSID.
If your devices don't connect, you could try contacting the vendors, or you will need to create a workaround. 🙂
I have read about some success with another router (or mobile hotspot) with the identical SSID and password so it connects to it. When the connection is successful, turn of the router, and it should connect to your Nest Wifi setup.
Check THIS link for more information.
05-13-2023 07:38 PM
Thanks for lending a hand, @RXShorty.
@Ourdarwin10, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
05-16-2023 10:41 PM
Hi Ourdarwin10,
Abi
05-17-2023 11:23 PM
Hello everyone,
Abi
