01-31-2023 09:33 AM
Looking for advice on why my google wifi does not function with my iPhone consistently.
Most days I lose the connection with a label stating “no internet connection”. Google Nest Support unfortunately haven’t been much help.
I have the same set up at my parents and it works fine, but it keeps going in and out at my apartment. Again, it’s just my iPhone. Everything else works great. Thanks.
02-02-2023 05:59 AM
Hey @Trojaboy .
Is the setup at your parent's home exactly the same (ISP, modem, network setup)? Do others with the same iOS device and/or iOS update having the same issues?
02-04-2023 04:09 PM
@PatrickP_Viking, appreciate your helpful response.
@Trojaboy, chiming in to ensure everything is good here. Were you able to see PatrickP_Viking's response?
Abi
02-06-2023 10:20 AM
Everything at my parents is different, and yes - other iOS devices have issues maintaining a connection. Please advise.
02-06-2023 09:34 PM
Thanks for the additional information @Trojaboy .
There are known issues with iOS due to default settings Apple enables. Please check out the below article. While it says "setup", these settings can affect connectivity as well.
02-12-2023 10:32 AM
Hello. Thanks for the information. All this was already done it appears. Still not functioning consistently.
02-12-2023 01:18 PM
Hey @Trojaboy .
Since the only apparent devices affected are iOS devices, it is likely a setting on either the devices or Nest Wifi that the devices are not playing nice with. Two things to try here:
If #1 resolves the issue then it will confirm that it was one or more of the Nest Wifi settings that are incompatible currently with iOS which we can get over to engineers to investigate further. If #2 resolves the issue, then it will confirm that the iOS device was the problem and you may need to reach out to Apple with a bug report or ticket regarding it.
If neither help, let me know.
02-12-2023 03:08 PM
Unfortunately, neither worked. The wifi works briefly then states “no internet connection”. -.-
02-12-2023 05:36 PM
Just out of curiosity, do you happen to have any special characters in the SSID?
02-13-2023 09:52 AM
There’s not. Only a 2.
02-14-2023 05:19 PM
Hey @Trojaboy .
Sorry for taking a bit to get back to you. I cannot find any known issue affecting Nest Wifi devices with the exception of the previous article. Since this only affects iOS devices, it is something with iOS that is causing the disconnects/reconnects. I suspect it is some setting on the devices, likely something enabled by default, that is the culprit that was part of a recent update.
I would suggest contacting Apple Support since it is only iOS devices having issues. They will try to say that it is the Nest Wifi but if only their devices are having issues, it is not the Nest Wifi. We have been through all of the known issues and fixes that I am aware of.
02-20-2023 08:04 PM
Thanks again for lending a hand, @PatrickP_Viking.
@Trojaboy, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
02-25-2023 09:45 PM
Hi Trojaboy,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Abi
02-26-2023 09:58 PM
Hello Trojaboy,
Abi
