Is Nest Wifi Pro compatible with Cox?
Phonzy
Is the new Nest WIfi Pro DOCSIS?
MichaelP
Hello @Phonzy
Nest WiFi Pro (like Nest WiFi and Google WiFi before it) do not include cable modem hardware. They connect to the internet through a standard Ethernet connection provided by a separate modem, like a cable modem for an internet service provider like Cox.
MichaelP
Hello @Phonzy
Phonzy
Thanks
That explains the setup required to install.
Jeff
Thanks for the input, MichaelP.
Hey Phonzy,
It looks like MichaelP was able to give you an answer on this. Before we mark this as resolved I would like to check in and see if you had any other questions or needs. If there's more you need, just let me know.
Jeff
Phonzy
Yes. MichealP's answer is the correct one. Thanks. I appreciate you checking in.
THanks
Princesss
Hi Phonzy,
We're glad that everything is sorted out. Since this has been resolved, we'll go ahead and lock this thread for 24 hours. Feel free to start a new one if you need assistance with your Google Wifi and the Community would gladly help.
By the way, thanks @Jeff and @MichaelP for chiming in and helping out.
Princess
