Nest WIFI Pro not allowing some apps or devices to not work (we are in the UK)
PhillipHutton
Please help
Bought and installed nest wifi pros, everything went well, and it shows i'm connected to the internet and am getting 935 Mbps. No problem connecting my google speaker and nest hub.
However, none of the amazon fire tv sticks will connect to the wifi. My children's playstation, they can watch You Tube, but cannot connect to some of their games. None of our devices will connect to netflix.
I have turned off the wpa3 in network controls, I have also disabled the IPv6 and this has had no effect.
Can anybody help?
David_K
Try changing your DNS provider:
Change your DNS server - Google Nest Help
I'd recommend 1.1.1.1 and 1.0.0.1 which are the ones provided by Cloudflare.
David_K
