Nest WiFi Pro PPPoE dialup
OS80
Can the new Nest WiFi Pro do a PPPoE dialup just like the old Google WiFi did?
I’m looking to upgrade speed and coverage, but want to make sure I don’t need an extra router for the dialup.  My existing Google WiFi dials up just fine (fiber connected to a transceiver, connected directly to Google WiFi).
8 REPLIES 8
Jeff
Hi OS80,
The setup process is the same with the new Nest WiFi Pro and it supports the same setup options as previous generations. The transition should be pretty much seamless for you if you choose to upgrade, but take note that the new WiFi Pro is not compatible with Google WiFi, so you won't be able to mix points and routers from the two systems. If you have any other questions, please let me know.
Jeff
Bungla
I have a VDSL connection (Vodafone UK) and I can not get the PPoE connection to work, is it possible to do with the Nest Pro?
Jhonleanmel
@Jeff, thanks for the help.
@Bungla, PPPoE is supported by the Google Nest Wifi Pro.
Mel
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Hi.
I have still not successfully connected through a PPOE connection
Jhonleanmel
Hi Bungla,
I suggest reaching out to your ISP to check if there are settings that needs to be configured to have the PPPoE enabled.
Mel
Hey Bungla,
Mel
Hi Bungla,
Mel
