Nest Wifi Point needs activation, but my country is not available for Device Utility App
Pitou_Mean
I bought Nest Wifi 3 packs from Ebay and send to my country (Cambodia). I could connect Nest Wifi Router successfully. But when I start Nest Wifi Point, it asked me to use Device Utility app. The problem is Device Utility app is not available in my country (Cambodia). Now what do I do to make it work?
olavrb
Try to set it up with a different Android or iOS device with the Google Home app, same Google account.
I don't think the Device Utility app should be used anymore, but you could sideload it, as in download the APK and install it manually:
I don't work for Google.
2 REPLIES 2
olavrb
Pitou_Mean
Thank you. I forgot that APK is a thing. I just switch from iphone to pixel 8 recently. I used VPN to download DU. But I think APK is the better choice.
