11-14-2023 02:50 AM
So this is a bit of a strange problem. In my house I have a spot where my phone (Samsung S21) connects to the wifi and does not get access to the internet. That is close to my PS5 and that has a connection through wifi (the same access point and a bit further away from it) and works just fine...
This is the only place in my house that this happends... I have tried to restart the entire mesh network several times, but this place seems to be a "dark spot" of some sort, and only for my phone? It connects fine to the network but is for some reason unable to connect to the internet...
Not sure if there is a solution to this... just wondered if someone else has had a similar issue and resolved somehow...
11-28-2023 02:17 PM
Hi Irishmanjjb,
We’re sorry to hear about the experience you’re having with your Wi-Fi connection, but since this is only happening on your Samsung phone in a specific spot in your house, we might need to isolate this further. A few questions:
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already. The steps above are normally used when troubleshooting internet issues; however, this is a different case where the issue involves only your phone and a specific spot. Still, we might as well try the steps and see if it works.
Let us know how it goes.
Dan
