11-20-2022 08:05 AM
We've been having issues connecting to specific sites on Nest Wifi (router and 2 points).
Tried all solutions in my original poast/thread, to no avail: https://www.googlenestcommunity.com/t5/Nest-Wifi/Google-Nest-Wifi-blocking-certain-sites-how-to-unbl...
We only run the 1 nest router, we changed DNS from auto to our ISP, and turned ipv6 off. In addition, our router and points completely went down a couple of weeks ago, and the only solution that worked was a factory reset of the Nest wifi. (Worked with ISP, everything was fine through the modem, it was definitely the Nest Wifi).
I'm frustrated at this point, we upgraded to Google Nest Wifi a couple of months ago as we have all Google products, and it's been more of a hassle than any other router we've had.... any other possible solutions would be appreciated!
11-29-2022 08:59 AM
Hi Liz27,
Can you let me know a few of the sites you are having issues with? Is it the entire site that won't display, or is it limited to some elements on the page (such as only the images on Instagram)? Is the problem constant, or is it sporadic?
Jeff
12-02-2022 09:59 AM
Hi Liz27,
Jeff
12-03-2022 10:23 AM
Hey Liz27,
Abi
