Nest wifi pro won't create network
hooryder
I can't establish the initial network. I bought the 3 pack to replace my other nest mesh system. I tried all 3 routers non of them work. Tried resetting them. Turn off the firewall from modem. It gets to the last part of set up and says failed every time.
My old nest works fine but the new one just won't do anything. I have At&t fiber.
3nigmagically
It may becoming an issue due to cascading routers or something similar. Placing your modem / gateway into bridge mode may also resolve the issue. Lastly, I would check the firmware versions on each device.
