09-10-2021 12:46 AM - edited 09-10-2021 12:49 AM
For the past week my Google nest Wi-Fi go randomly off-line. There have been absolutely no other changes in my network or environment that could cause this. I’ve had no issues prior to this.
I can see a couple of posts in the forum of a similar vein, has anybody been able to solve this issue? Is it a firmware problem?
I’ve done a full factory reset which hasn’t helped, and in fact seems to have made it worse.
Setup: Router (firmware 13729.57.27) and 2 points (firmware 1.54.267572)
any ideas?
09-10-2021 07:00 PM
I have the same problem also. I've had my Nest wifi and Google wifi for almost 2 years without any problems and now I have them daily. When plugged in with Ethernet cable, internet is fine. This problem seems random. Lasts 5 to 10 min then spontaneously resolves without intervention. Another forum suggested too many wifi points and they were causing interference. I've just reduced mine from 5 to 4. Too soon to tell if that helps.
09-23-2021 01:14 PM
Hey, Sydtriman.
Thanks for the update. Sorry that you're still dealing with that issue. I unfortunately don't have any new updates to share right now, but I wanted to keep in touch to let you know it's still being looked at internally. I'll keep things updated as I find out more.
Thanks.
09-27-2021 07:18 AM
Hi Jeff,
Do you have an update on this issue? I have sent feedback multiple times. The problem becomes worse and my gen 1 wifi routers go offline multiple times a day. I can't work with an unstable router. We need a fix asap. Thank you!
01-05-2022 09:28 AM
I have this problem also!! DAILY SEVERAL TIMES DAILY!! I will continue to make bad google reviews until this problem is fixed!! Too much wasted time since September and your useless updates!
01-05-2022 09:42 AM
They are working on it, and have been on the case for 4 months now. I'm sure a fix is imminent.
...and if you believe that, I've got some beachfront property to sell you in Arizona...
01-10-2022 12:46 AM
I hope this will come soon indeed. On my side, Google support gave me no indication about that ...
02-06-2022 02:22 PM
Curious why a firmware rollback was never attempted. I feel my issue started some time after the Nov update and have progressively gotten worse.
02-26-2022 06:29 AM - edited 02-26-2022 06:31 AM
Because the firmware rollout was in response to losing a patent lawsuit. They had to push the firmware to remove the infringing technology. They legally can not revert. This never would have been an issue had they not decided to integrate Google Assistant Speakers into their WiFi devices. They lost a patent lawsuit regarding the speakers to Sonus. They had to strip the offending code from their devices. Had they never pushed the speakers into WiFi, Google WiFi would still be great.
02-25-2022 08:49 PM
Good one. I spent two wastes hours on the phone talking with…a “specialist”
02-25-2022 08:48 PM
I too am getting frustrated ….and such an expensive system, and seemingly well designed, except for it going off line.
02-25-2022 11:43 PM
If you were serious, my apologies. But otherwise, hilarious. "Well designed in theory, other than the fact that it doesn't actually work. "
01-26-2022 03:03 PM
I am also having this issue, it only seems to be affecting my mesh point? Any news on fixes yet? Or maybe it's time for yet another factory reset.... Ugh.
01-29-2022 01:46 AM
Ever since nest “migrated “ with google all I’ve had is problems. Offline several times a day…and still paying full price for something that is worthless!! Very upset that we have cameras we cannot utilize because they are offline most the time!!!
a month ago
Still having issues JEFF. Google needs to make good on this.
2 weeks ago
Yeah. Apparently this has never been solved.
At promising as every Google product ever released..they have almost all failed in their attempts.
They should probably just stick to search and selling your data.
Awful. Awful products
Friday
Same here - Nest router + 1 nest point and 3 google points and the Internet goes out for several minutes, randomly several times each day. Firmware is up to date. Tried manufacture resets and, agree with other poster, I think that made the issue worse.
09-14-2021 01:27 PM
Hi, Sydtriman.
Thanks for reaching out and I'm sorry to hear about the issues with your network going offline. I'm sure this is frustrating to deal with.
So there is a known issue here and we are actually rolling out firmware updates to WiFi devices now. The update is hitting devices as we speak, and your Nest WiFi will automatically update soon.
In the meantime, you can actually share feedback directly with our teams which will help us more rapidly develop fixes for these sorts of issues. To do that, follow the instructions below:
I'll keep things updated as I learn more. Thanks.
09-16-2021 12:20 AM
Thanks Jeff
I have previously sent feedback and I am also keeping an eye on the firmware version. As of yet there hasn’t been any updates. Regrettably it is still intermittently going offline. ☹️
10-05-2021 10:00 AM
Hi, all.
I don't have any updates yet, but I am speaking with the internal teams later today. I'm hoping we have more then, but I will definitely let you all know when there's more to report.
Thanks.
10-05-2021 12:40 PM
Thank you!
it’s amazing, I’ve had no drops for a week and then all of a sudden it happened again yesterday and have had at least 3 (that I saw, they don’t always reflect in the history). Absolutely nothing else has. Hanged in the network. Very odd.
02-08-2022 11:46 AM
I don’t believe you or Google.
02-08-2022 11:50 AM
The funny thing is that this was October. He posted something similar in September. And November. And December. And January. And just recently...
02-08-2022 12:44 PM
yes and everyone should call him out,
a week ago
okay, this is 5-2022, why isn’t this problem fixed? I spent all this money to purchase this Wi-Fi nest system and now my Wi-Fi points an$ router goes off line continuously therefore my other devises I am so sick of this system. I have tried everything. Sick and tired, sick and tired. I want my money back for this junk
04-14-2022 07:10 AM
You all can't possibly still be 'working' on this and not have diagnosed and resolved the issue... what is going on at the 'King of Tech' that has you all stumped? This is horrendous customer care, especially in thsi day and age of WFH...come on Google, get it together!!!
09-20-2021 02:03 PM
I have the same problem too. The randomly going offline started when M89 firmware came out. I also reported it in this link (https://support.google.com/googlenest/thread/116896459/m89-firmware-is-unstable-on-google-wifi?hl=en). A few days ago, the problem became a lot worst. It became offline twice a day. The Wifi router and points are running firmware 13729.57.27. I have also sent the Feedback to Google.
12-30-2021 08:49 PM
It is happening to me too
10-06-2021 05:41 AM
I'm having exact same issues since the recent update. The router's fine. But the Point drops connection on daily basis without rhyme or reason.
10-06-2021 01:49 PM
They just gave me a replacement router (despite me saying that it was not a hardware issue) and ... surprise, it is still doing it.
Question @MicrophoneCheck do you have any home automation (lights etc) or Apple HomePod type devices on your network?
10-06-2021 02:59 PM
I have Mac, Windows 10, Windows 11 and Chromebook on the network and a Facebook Portal but no smart devices.
There are several other people who are having similar internet issues on the reddit:
https://www.reddit.com/r/GoogleWiFi/comments/ph1gn8/137295727_firmware_update_latest_cant_find/
10-07-2021 09:10 AM
Hey, all.
Just as a quick update, we are still looking at this internally. I know it feels like the process is slow, but there's a lot to pour through with the reports coming. As soon as I know more about the situation. Also, thanks for sharing the reddit thread. The more instances we can find, the more it helps.
Thanks.
10-24-2021 12:36 PM - edited 10-24-2021 12:37 PM
11-16-2021 09:40 AM
Hey, everyone.
I see there's a few more people with the issue, and it's something we're still investigating internally. We know it's a problem that's being seen a bit more in the community, but as of right now I don't have any updates quite yet. I will keep the thread in the know as I find out more.
Thanks.
11-17-2021 10:09 AM
Hey, everyone.
We're still discussing this internally and testing situations and different factors. I have a series of questions and things to check with your intermittent connections. I realize some of this has been answered or checked, but as we're gathering very specific info right now, it would really help us move things along. Thanks so much for your input.
Network Connectivity Questions:
How long did the WiFi network work properly before encountering connectivity issues?
How did you discover that the network was having connectivity issues?
Did any of the WiFi points give audible errors, such as:
“I can't reach the internet right now. Check your modem or router connection and try again.
“I can't connect to the Wi-Fi network. You might want to check the connection settings in the Google Home app”
Something else? (Please note the error message, or how the issue was discovered)
WiFi Setup Questions:
What is your WiFi setup? (single router or multiple access points - how many?)
What is the location of the affected WiFi point in relation to other WiFi Access Points/Routers? (please note distance, in same/different room, same/different floor, any major obstructions/interference like walls, floors, cabinets, appliances etc?)
Did you change yourWiFi setup recently / was it was working fine before / what did they use before and what did they swap to?
If you know any of this info, please provide it as well:
Router brand (make and model)
Router security, such as WEP, WPA, WPA2, etc
Router software version
What's the configuration of the network? Are you using a mesh network, WiFi repeaters etc?
11-19-2021 01:42 AM
- It would work anywhere from a few hours to couple of days.
- Loading websites would timeout or speed would be limited to few kilobytes/sec.
- I think I've heard both. Can't remember exactly but I do remember an error starting something with "I can't..."
- Single router w/ Nest Wifi Router and one Nest Wifi Point
- Router is upstairs. Wifi Accesss point downstairs. Intereference being
- No changes have been made to the network setup.
- Mesh configuration with one Nest Wifi Router and one Nest Wifi Point
-- Along with above answers, I want to reiterate that connectivity issue only started to happen just recently.
12-22-2021 01:10 PM
I'm adding my issue to this cue as well. Glad I'm not the only one having this issue randomly pop up at the exact same time...
Six months
Dropped WiFi connection and/or weak signals.
No, I have Google wifi without Asst
2019 Google Wifi with 1 router and 1 access points. Just added a second access point to extend the signal and hopefully improve connectivity, but the same issues persist. The second AP is a newer model with Asst.
1 AP in a detached garage approx. 20 feet from the nearest AP and approx 40 feet from the router. The AP and router in the house are not separated by full walls, but do not have direct line-of-site. The second AP is two walls apart. Note... there were NO issues until just recently and nothing has changed in the environments. The signal just started dropping suddenly.
No change
Google Wifi AC-1304
Default security
Unsure
Mesh network with 1 router and 2 APs
11-30-2021 01:47 PM
I've been having the same issue, but my Nest goes down again after reset in just a few minutes. Google needs to step up and get this resolved or have a recall for this crap equipment
12-30-2021 08:50 PM
Same here
01-20-2022 06:15 AM
Yup, crap, it’s been doing it here for 6 months, f Ing sick of it
