Network cable connected, network cable not connecting
danceangel_1
Connection issues, cable is connected then cable is not connected repeatedly. Light flash on then off  repeatedly
jenniffert
Hi danceangel_1,
Thank you for reaching out to our community! I understand that you’re experiencing intermittent network connectivity issues, where your cable is constantly connecting and disconnecting and the network light is flashing on and off repeatedly. No worries, I'm happy to help!
To provide you with the most accurate information, I’d like to ask for the following information:
In the meantime, please check if the Ethernet cable connecting your devices is a CAT5e cable or higher. For reference, see this article: Hardwire Nest Wifi Pro, Nest Wifi, or Google Wifi with Ethernet.
Jenniffer
