03-05-2022 06:17 PM
Hello, I followed this topology:
✓) Modem → Google Nest Wifi router or primary Wifi point→ Switch → Google Wifi point(s)
via wired Ethernet.
There are 3 routers connected and the wifi signal is excelllent in 2 of those but the wifi signal of primary router fall at mínimum. Have you seen this problem? There is a solution?
03-06-2022 06:59 AM
Hello @ChristianGN2021
Two questions:
1. How close is the primary to your "modem"?
2. Is your "modem" actually a combination modem + router + WiFi access point?
My suspicion here is that your "modem" is still providing WiFi and causing interference with the primary Google WiFi unit. I am also assuming you're testing this with clients near the primary and that you've verified those clients are actually connected to the primary (some clients tend to "stick" to a distant access point that is still reachable rather than switching to something closer).
03-07-2022 07:28 PM
Hello MichaelP! Thank you a lot for your response. I will check if my módem is providing wifi also.
The primary router is very close to the módem (50 cm).
Yes, is a combinación of modem+router+wifi.
03-11-2022 09:24 AM
Hey, ChristianGN2021.
I just wanted to check in real fast to see if you were able to look into those suggestions MichaelP made and if it helped work things out for you. Let me know if there's anything else we can do for you here.
Thanks.
03-15-2022 01:53 PM
Hi again, ChristianGN2021.
I just wanted to check in and see if you were able to make any more progress on this and to see if there's more I could do for you here. If so, just let me know.
Thanks!
03-16-2022 03:28 PM
Hi, everyone.
Thanks.
03-07-2022 03:34 PM
Hi, ChristianGN2021.
I just wanted to jump in real fast to see if you saw MichaelP's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
03-17-2022 02:38 PM
Hello! I’m sorry, I went on vacation and just got back. I checked the wifi signal of the provider’s router and it was indeed activated. I disabled it but the problem persist. I changed the connection por and the first Speed test was successful but then the speed drop. What I have notice is that the the signal is strong but the speed is what fails.
03-23-2022 02:09 PM
Thanks for checking in. Sorry that things still aren't 100% for you. We do have a new firmware version rolling out to devices right now, so hopefully that will help clear this up for you. Once that firmware hits, take a look at the network again and see if it's managed to stabilize. There's nothing you need to do in order to receive the update, it will download and install on its own.
Thanks.
04-15-2022 11:59 AM
It's been a while since we touched base so I wanted to see if you ever received that firmware update and to see if it made any difference for you. If you're still waiting on it, it should be arriving soon. If you're still looking for some input on this, just let me know.
Thanks.
04-20-2022 10:07 AM
I just wanted to follow up once more to see if you ever received that update and if you managed to see some improvement in your network connection. Let me know if things are still not working properly.
Thanks.
04-20-2022 07:23 PM
Hello Jeff! I did not receive an update. I still have the problem. I thinking change the System…
04-25-2022 02:24 PM
By today you should definitely have the update on your network. If you aren't seeing it, try power cycling the router and points on your network. Upon the restart, it should go into update mode. Give that a try and see if it prompts the update for you.
Thanks.
04-26-2022 06:27 AM
Hello Jeff, I will try it on this week. Let talk this weekend.
04-26-2022 01:06 PM
Sounds good, ChristianGN2021. Let's hope all goes according to plan.
05-11-2022 01:33 PM
I'm just checking in again to see if you had any update on this. Hopefully things worked out!
05-18-2022 10:50 AM
Hey, everyone.
It looks like we've slowed down here again. We'll be closing up the thread unless anyone else has any input or needs anything else. If so, just let me know and we can keep this open a bit longer.
Thanks.
05-23-2022 12:47 PM
Hello Jeff, I’m sorry! I just try the connection and it seems excellent. I just need to test the stability of the network, wich I will do today and tomorrow. I appreciate your concern and attention to my case.
05-24-2022 10:03 AM
No, problem! Just let me know if you see any issues there.
Thanks!
06-01-2022 02:06 PM
I am checking back in to see if you were able to test things out. If you haven't had a chance yet, no worries, but if things are working well that would be great news! Let me know if you have noticed anything for better or worse.
Thanks.
