Samsung TV model: un55es6150f want connect to goggle mesh
JimmyA143
Samsung TV un55es6150f will not connect to google mesh, can’t even find network. Worked with fire stick but moved to kids room and want to use TV with out.
please help and thanks!
6 REPLIES 6
Tuzza
Have you got WPA3 enabled in your WiFi settings? If so try turning it off, your TV might not like WPA3.
JimmyA143
It’s been turned off, that’s apparently not the problem. Thanks for the help though!!
EdwardT
@Tuzza, thanks for the help!
@JimmyA143, thanks for reaching out. I'm sorry to hear that your having an issue with connecting your Samsung TV to your Wifi. I'd love to know more about this and I have a few questions:
  • How far is the TV from the router?
  • Is the TV detecting any other Wifi names?
  • Have you tried manually putting in the SSID and password?
Edward
EdwardT
Hi JimmyA143,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
Jeff
Hi, JummyA143.
I just wanted to jump in real fast to see if you saw Edward's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
- Jeff
Jeff
Hi again, JimmyA143.
I'm checking back once more to see if you still needed help on this. If so, just let us know.
- Jeff
