Setting up wifi point with no QR code
GVargas
We were having issues with our mesh wifi system connecting to our home group so I reset all of the wifi nest points and router. Upon setting up the system again, on of the wifi points Model H2E does not have a QR code on the bottom and no set up codes. Without this mesh point connection our internet connection has not been reliable, can someone please help?
David_K
H2E is the Nest Wifi point. The code is engraved into the bottom of the device right at the edge near the power connector. Since the rubber is a grey colour and the numbers are recessed into the rubber, it can be pretty easy to miss, even with multiple looks. Make sure you have plenty of light and maybe take one more peek?
LovelyM
Your advise here is greatly appreciated, @David_K
@GVargas, thanks for reaching out. Were you able to follow the suggestion that David_K provided? That should help you get your Google Nest Wifi point's setup code. You may also visit this link for further help.
Sincerely,
Lovely
LovelyM
Hi GVargas,
I know it has been a while, but I want to ensure that everything is covered on your end. Please inform me if you still need a helping hand.
Lovely
