Should we wait for Nest Wifi Pro?
STLSTeve
Hi.
We just upgraded to Spectrum 1 gb internet so we need to upgrade our five year old mesh system to take advantage of it. We currently have three pre-2020 MacBook Pros, an older iMac, and several recent iPhones. We stream music from our devices to stereos and video to our tv. Videoconferencing using zoom and teams is very important to us as we work from home. There are three of us in the house, two adults, one teen. We use three levels of our home and the basement. We have two home offices on two separate floors. Will there be an advantage for us to wait for the Nest Wifi Pro or would we get the same functionality with our needs and current devices with the current Nest Wifi? Thanks for your help
RXShorty
Hi @STLSTeve
The most significant difference between the Nest WiFi and the Nest WiFi Pro is the support for WiFi6e or even WiFi6 in general. As WiFi 6 has some advantages and is the newer product, I would say yes, wait for the new Nest WiFi Pro.
  • The Pro is more future-proof with WiFi 6E support, sure, your current hardware does not support this yet, but your future device probably will.
  • The Pro is newer, so my educated guess is that support will last longer.
So my advice would be to wait for the newer version. 🙂
olavrb
In addition to this, I'd also mention the dedicated wireless backhaul as one more great addition in regards to performance. Here are some more details on the benefits:
Here are specifications for all Google Wifi and Nest Wifi pucks:
That said, if you can find some Nest Wifi routers (not add-on points) on the cheap, those will serve you well too. Don't think you'll notice much of a difference, but time will show as reviews and benchmarks get out.
I don't work for Google.
EmersonB
Hello everyone,
@STLSTeve I'm dropping by to ensure that everything is covered here. I hope the information above sheds some light on the issue. If you have other questions and concerns, feel free to let me know.
@RXShorty and @olavrb I appreciate your helpful response.
EmersonB
Hi STLSTeve,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
EmersonB
Hello STLSTeve,
We haven’t heard any updates from you. I’ll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
