12-09-2021 08:31 AM
Hi Support Team,
I have Google Nest Wifi Router with two points. When I'm doing the mesh connection points test it says good speed, and also when I'm doing the speed test it says 500MB download which is good. The problem is when I'm using other speed test apps, sites like okla, speedtest.com, fast.com I'm getting 60MB download speed connection via my Iphone 12. Also, I tried to do a speed test from my smart tv, and I get the same slow speed results, 50 -60MB speed download. Note: My speed at home is 500MB, and when I'm using LAN directly, I'm getting 500MB, but wifi is 50 -60 mb via other download speed test apps and sites.
Can you please assist and let me know why I'm getting such a slow connection via wifi with Google Nest?
Nir
12-17-2021 12:21 PM
I have the exact same issue. I have a 1Gbps (official) connection. The speed from the Nest router is very fast, no problem there. However on all my WiFi devices its varies between 20-50Mbps... Fastest i've seen is 70Mbps.
I've tried moving the points, resetting everything. Including standing right next to the router when testing. No dice.
01-28-2022 02:54 PM
Hey, goldshlager.
Sorry for the late response here, but I wanted to check in to see if you were still having this issue and to see if you have done any additional troubleshooting so far. If you still need help, let me know and I'll be happy to work on this with you.
Thanks.
01-31-2022 02:41 PM
Hi, everyone.
Thanks.
01-31-2022 03:03 PM
Hello Jeff
I still have this problem. I even changed my router
02-02-2022 10:36 AM
Hi, Shifty.
Did you get a replacement router from support? Which router are you now using?
Thanks.
02-02-2022 10:46 AM
Hey
I'm still using the Gen2 Nest router. I meant the fiber box from the ISP, fiber modem.
02-02-2022 01:28 PM
Ok, thanks for clarifying that, Shifty.
With the new modem you got, is it a modem only, or is it a modem and router combo? Does it create its own wireless signal as well?
02-02-2022 01:34 PM
Hello Jeff
Its a router modem combo. I have disabled All WiFi on the router modem combo
02-02-2022 01:51 PM
Ok, Shifty. That's good information for me to work with. I'll take a deeper look into things now that I know more and will return when I know some more for you.
Thanks.
04-01-2022 11:54 AM
HI Jeff, I am having the same issue with Sky Wifi. Wifi on the main modem is 800Mb while if I use Google Nest I get max 60 Mb in Download and 120Mb in upload... very strange.
How can I fix it?
