01-05-2022 12:33 PM
Hello, I have a 1 TB internet connection with my ISP, usally I don;t get the full speed, perhaps about 650 mbs. To my ISP modem I have connected a google wifi point via ethernet using a CAT7 ethernet cable. When I test the speed of the modem, I get above 600, when I test the speed of the google point I get half or less of the speed. Which means that I'm loosing speed between modem and point. How can I resolve this issue? Thanks
01-11-2022 03:31 PM
02-18-2022 11:21 AM
Hey, manuelguillen.
Sorry for the late response here, but I wanted to check in to see if you were still having this issue and to see if you have done any troubleshooting so far. If you still need help, let me know and I'll be happy to work on this with you.
Thanks.
02-24-2022 01:43 PM
Hi, manuelguillen.
Thanks.
02-24-2022 02:24 PM
Sorry for the late response!!! The situation still the same, My modem registers like 600 and the google wifi registers like 250. Don’t know what the problem is!
02-25-2022 10:08 AM
Hey, manuelguillen.
When you run the speed tests, are you running that through the Google Home app or using another speed test? If so, are you able to also run a mesh test and let me know what connection strength your WiFi points are showing?
Thanks.
02-25-2022 10:12 AM
Hi, Jeff! Let me run the tests and I'll get back to you! Thanks for your help!
02-28-2022 10:55 AM
No problem, manuelguillen. Just let me know how things look when you get a chance to run through those test.
Thanks!
03-09-2022 09:34 AM
Hi, mnauelguillen.
It's been a little while and I wanted to check in to see if things worked out for you or to see if you still needed some help here.
Thanks!
03-21-2022 10:04 AM
Hey, everyone.
It looks like we've slowed down here again. We'll be closing up the thread unless anyone else has any input or needs anything else. If so, just let me know and we can keep this open a bit longer.
Thanks.
03-29-2022 01:34 PM
Hi, everyone.
Thanks
