What cat 6 cable do I need to connect mesh hub to additional access point
24879845
What cat 6 cable do I need to connect the mesh hub to an additional access point is it straight through or a cross-over?
Thanks in advance...
6 REPLIES 6
RXShorty
Hi @24879845
You can use a regular cat 5e or cat 6 cable. 🙂
olavrb
All Google Wifi and Nest Wifi with ethernet ports (that excludes the "Nest Wifi point", which has no ports) has gigabit ports:
Any ethernet cable that is gigabit compatible (or greater) within the length of which you are going to use should be fine. Typically CAT5e, CAT6 and CAT6a.
I don't work for Google.
danbauer
Any CAT6 cable will do just make sure it’s long enough to reach the point
AbigailF
Thanks for lending a hand, @RXShorty, @olavrb and @danbauer.
@24879845, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
LovelyM
Hello everyone,
We want to ensure you are good to go. Please reply to this thread if you still need assistance so we can give you a helping hand.
Lovely
AbigailF
Hi again folks,
Thanks for your help here, @LovelyM.
Abi
