01-10-2023 05:37 AM
I have one Nest WiFi Pro router and four Nest WiFi Pro points.
For weeks, the mesh test has reported three of the points with a "great" connection and one with a "good" connection.
However, starting a couple of days ago, the mesh test consistently reported that ALL FOUR points had a "weak" connection. I ran this test several times over the past couple of days.
So this morning as an experiment, I used the Google Home app to restart one of the points. Then I did a mesh test again and, sure enough, the restarted point reports a "great" connection again, but the other three still showed as "weak".
So I individually restarted each of the other three points and did another mesh test I am now back to normal, with three "great" connections and one "good" connection.
So I have apparently solved the problem for now, and we'll see if it happens again. But my question is this: What on earth would cause this to happen?
Isn't it suspicious that ALL the points turned "weak" at the same time, and that the problem was fixed by restarting them? This smells like a software bug to me. What is going on? What would cause this to happen?
04-03-2023 06:15 AM
@Kurelgyer at this point I'm considering switching myself. Which brand did you switch to, if I may ask?
04-08-2023 06:29 PM
Hi there drrmjones,
I checked your original case again and saw that our senior specialist recently replied to your email. Please reply to the senior specialist once you have an update. I’ll keep this thread open for a few days in case you need more help from us as well.
Abi
04-11-2023 07:53 PM
Hey everyone,
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
04-12-2023 08:13 PM
Hello everyone,
Abi
03-19-2023 03:52 PM
Please dont lock this thread!!! I have had this issue several times now and dont believe it has been permanently resolved. We need this thread kept open so we have continuity and get this issue which is a major problem for us resolved.
07-07-2023 11:49 PM
I've actually been hit with a similar performance drop recently where connections that have been great in the past have suddenly become intermittent and are weak. @Kurelgyer how are the Deco's doing thus far? I'm thinking about cutting my losses, recycling my Nest Wifi Pro's, and going to tplink.
07-14-2023 01:12 PM
Hi all, i have starting having the same issue since last google home app sw version on IOS done last week. It only work well for a few hours after a factory reset on the wifi router. This is very annoying and i hope Google can cover this asap.
