When connecting Nest wifi point to Nest router and scan QR code Google Home app says QR code is wron
ElizabethMorten
I have a nest wifi router and two nest wifi points which have been working well. Due to some connection issues with the one Nest wifi point I ended resetting it to factory setting. After that it is impossible to connect the Nest wifi point to the Nest router.  When connecting using Google Home App and preparing Mesh network then when scanning the QR code I get the message "It is not the correct QR code", when typing in the code from the bottom of the Nest wifi router I get the message "Connection could not be established". I have tried to connect to the Nest wifi router using the address http://192.168.86.1/api/v1/status I do not get any pass code as described here: Google Nest Wifi device or Google Wifi point doesn't have QR code - Google Nest Help
What to do?
Kind regards,
Morten
8 REPLIES 8
Juzdu
So what do you see when you go to  http://192.168.86.1/api/v1/status on the Nest Router?
Hi; I get this information:
   "setupState": "GWIFI_OOBE_COMPLETE",
   "software": {
      "blockingUpdate": 1,
      "softwareVersion": "13729.57.27",
      "updateChannel": "stable-channel",
      "updateNewVersion": "0.0.0.0",
      "updateProgress": 0.0,
      "updateRequired": false,
      "updateStatus": "idle"
   "system": {
      "countryCode": "nordic",
      "groupRole": "root",
      "hardwareId": "MISTRAL D2J-A2C-A3R-I72",
      "lan0Link": true,
      "modelId": "MISTRAL",
      "uptime": 149285
   "vorlonInfo": {
      "migrationMode": "voobed"
   "wan": {
      "captivePortal": false,
      "ethernetLink": true,
      "gatewayIpAddress": "10.0.0.1",
      "invalidCredentials": false,
      "ipAddress": true,
      "ipMethod": "dhcp",
      "ipPrefixLength": 24,
      "leaseDurationSeconds": 43200,
      "localIpAddress": "10.0.0.249",
      "nameServers": [ "8.8.8.8", "8.8.4.4", "10.0.0.1" ],
      "online": true,
      "pppoeDetected": false,
      "vlanScanAttemptCount": 0,
      "vlanScanComplete": true
EdwardT
@Juzdu, thanks for the help!
@ElizabethMorten, Thanks for reaching out. Since you're device is connected to the router that is already set up, it's not going to give you a passcode for the point that you're having an issue. To isolate the issue further, could you try resetting the point to the factory settings again before trying to set it up?
Let us know how it goes.
Edward
Hi Edward,
Tried to factory reset many times without any help, still gives the same message. Same goes for perforiming  http://192.168.86.1/api/v1/status on the Nest Router
Have you tried Google support?  I'm guessing they'll be able to fix this issue pretty easily with access to your wifi system.
Jeff
Hey, ElizabethMorten.
I just wanted to jump in real fast to see if you saw Juzdu's reply and to see if you had any luck contacting support. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
Jeff
Hi, everyone.
Thanks.
Jeff
Hi, everyone.
Thanks
