09-06-2022 12:51 PM - edited 09-06-2022 01:07 PM
Hi all , just set up the best wifi mesh. I have the router connected to my Vodafone broadband router. My question is the Vodafone wifi network still works. Is this correct or should I be switching off the voda wifi on the router somewhere?
My Vodafone package is the full fibre FTTP one so I’m not sure if I should even be connecting the nest router to the voda router? Or should I be connecting direct to the wall unit?
sorry I’m not very technical so any help appreciated
09-06-2022 11:06 PM
Your Google nest WiFi primary point should be connected to your MODEM. You should not use other brands of router with Google mesh systems.
09-06-2022 11:25 PM
Yeah but my Vodafone modem and router are the same device. What should I do in this instance?
09-07-2022 03:26 PM
I had same. Either disable DHCP in wifi settings on the Voda (turning the Voda into bridge/modem mode) or as I did bin the Voda and go get a standalone modem. I recollect I did later as the Nest Wifi did not support Mesh mode when connected to another router. ie: I could not add a Nest wifi point to network.
09-08-2022 07:30 AM
Hmmm, this may be my problem. I have a T-mobile cellular modem which works quite well for devices connected to it's wifi network.
However, I have a home office that is at the other end of the house and need to extend my wifi network to get better wifi at the home office. Scrapping the T-mobile modem is not an option for me.
I purchased 2 Nest routers at the suggestion of T-Mobile and successfully created a new wifi network (N1_wifi) with the first Nest router. I have had no success setting up the 2nd Nest router as a point in this new network.
09-09-2022 12:56 AM
Thanks all , the way I have done it is turned off wifi on my Vodafone device. It seems to be working fine apart from speeds when connected to the WiFi points rather than router are slow. I’ve not disabled dhcp on my voda router, is it worth trying that?
09-09-2022 02:14 AM - edited 09-09-2022 02:16 AM
The Nest Wifi router will issue its own DHCP. So yes, you can turn off the Voda DCHP as you're not really using it. Out of the box the Voda will have 192.168.1.1 as router address whereas the Nest router will have 192.168.86.1. So, they are different networks. End result will be your using the Voda in Modem/Bridge mode and Nest will handle the DHCP.
09-09-2022 02:49 AM
Expect some drop-off of speed if connected to a point rather than the router. Thats the price of mesh. In my set up I have a crappy Voda 40/10 VDSL circuit and connected to Router I get circa 34MB download and circa 8MB upload. If I am connected to my kitchen point I see that drop slightly to 30MB download and same upload. if go outside in garden and still connected to point speed drops off significantly to sub 20MB download. Depending on where your points are in relation to router will dictate the drop-off you might experience when connected to a point.
09-10-2022 04:41 PM
NOBBY0_15, cwskas, and Beenpierced, thanks for the help.
YNS, I hope you've got the answer you're looking for.
Give these steps a try to improve your network speed:
Let us know how it goes.
Mel
09-10-2022 04:48 PM
Hi
thanks , when you say set custom dns , how do I do this? Is it on the Vodafone router or on the nest router?
09-10-2022 05:11 PM
Hi YNS,
To set a custom DNS follow these steps:
Keep us posted.
Mel
09-10-2022 10:57 PM
Thankyou
I tried this but now my WiFi seems to be offline and won’t come back again. I can’t even get back in to revert the settings back?
any ideas?
09-11-2022 12:09 PM
Hi YNS,
Thanks for the update and I'm sorry to hear that. Try to reboot your network by unplugging your Google Wifi from the power for 2 minutes.
Let me know how it goes.
Mel
09-14-2022 01:02 PM
Hey YNS,
Checking back in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Mel
09-15-2022 06:47 PM
Hey YNS,
Edward
