WiFi won’t reconnect to doorbell cam
lamp1
2 REPLIES 2
@lamp1
You haven't provided enough information for other customers to offer suggestions. Did you update your Wi-Fi? Did your doorbell just drop offline? Which specific doorbell do you have?
Or you could try contacting Support:
maedacortez
Hi lamp1,
Thanks for reaching out. I understand that your Nest Doorbell is not reconnecting to Wi-Fi. I know this can be frustrating, but don't worry, I'm here to help! Before I can assist you further, I'll need to ask a few questions to better understand the situation.
  • What model of Nest camera doorbell do you have?
  • When did the issue start?
  • Are you getting any error messages?
  • How far is the camera from the router?
  • Do you have other Nest devices in the house?
  • Are there other devices connected to the same Wi-Fi where the camera is connected?
  • Can the camera find other Wi-Fi networks?
  • Are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera?
  • What Wi-Fi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
  • What troubleshooting steps have you done so far?
I will awaiting for your response.
Manuel
