09-12-2022 09:52 AM
Is there ay way to adjust the actual "Power" of my router? So it's not emitting such a strong signal but still works? I know this sounds weird..THANKS
09-12-2022 11:17 AM
Nope, there is currently no way to adjust transmit power on Google Wifi or Nest Wifi.
09-12-2022 11:17 AM
Hello @pmbridges
Transmit power is not adjustable on Google/Nest WiFi products. In relative terms, the transmit power is quite low to start with, though. Reducing the transmit power can have counterintuitive effects as well. For example, reducing the transmit power may require sending data at a lower speed, meaning the transmitter may actually be on longer than it would be at the higher power. Since this product is intended for typical consumer use, it's unlikely they will expose this as a configurable parameter due to the increased likelihood that it will result in poor performance and unexpected behavior.
09-15-2022 03:02 PM
Hi pmbridges,
I just wanted to jump in real fast to see if you saw olavrb's and MichaelP's replies and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
09-19-2022 10:48 AM
Hey pmbridges,
I just wanted to follow up once more to see if you were still needing some help here. If so, just let us know.
Jeff
09-20-2022 11:47 AM
Jeff
