02-23-2023 01:18 PM
Is there a way to get Google to work with log in details or using DHCP 61.
Seems strange that Google wouldn't allow connection by WAN
02-23-2023 04:18 PM
Openreach connections normally rely on PPPoE. Your ISP should be able to help with the settings.
02-23-2023 11:51 PM
Even if it's full fibre ?
02-24-2023 03:41 AM
Yes. You would plug the Nest in to the ONT (the device in your picture) and you should be able to connect via PPPoE in most cases. Check with your ISP to be sure. I used to work in tech support for an ISP and as far as I'm aware things haven't changed in the last year since I changed jobs.
02-24-2023 05:33 AM
Thank you I'll contact sky 👍
02-24-2023 08:43 AM
Good luck. In the past Sky used to be a bit fussy about people using their own routers, but they may have changed.
02-27-2023 11:02 AM
Hey Rgm700,
I wanted to check in and see if you had a chance to contact your ISP and to see if you learned anything there that would help sort this out. If you still haven't had a chance to speak with them, just let us know.
Jeff
02-27-2023 11:06 AM
Haven't had a chance yet I was going to message them tonight 👍
02-27-2023 01:05 PM
Sounds great, Rgm700. Just let us know if they give you any ideas that will let us help out more on this.
Jeff
03-03-2023 08:42 AM
Hey Rgm700,
It's ok if you still haven't had a chance, but I wanted to follow up once more before the weekend to see if you had any new info from your ISP.
Jeff
03-07-2023 10:59 AM
Hi again, Rgm700,
Just another quick check in to see if you managed to get a hold of your ISP.
Jeff
03-07-2023 12:24 PM
Actually just on the phone now to them so hopefully I can get it 👍
03-07-2023 01:08 PM
So spoke to sky and they said the user name is admin with the wifi password. This doesn't work though
03-08-2023 08:49 AM
Hey Rgm700,
Just to clarify, the ISP was trying to provide you the info to log into the modem so you can change its settings, correct? When you are referring to the login info, you're not talking about the info to change anything on the Nest WiFi Pro device, are you? Can you clarify a bit more about the steps the ISP gave you?
Jeff
03-12-2023 07:20 PM
Hello Rgm700,
Abi
03-13-2023 07:52 PM
Hi Rgm700,
Abi
03-14-2023 01:34 AM
No this was the login so I can connect the Cable directly from fibre to the WAN port. It was meant to be the PPPOE log in details
03-15-2023 03:57 PM
Hey Rgm700,
Thanks for the update. To confirm, did your Internet service provider give you a modem to connect your ONT box to or is your ONT box directly connected to the WAN port of your Google Wifi router? We’ll wait for your update.
Abi
03-16-2023 12:10 AM
Hello, they did provide me with a router that connects to my modem on the wall. I have to connect the Google nest to the router provided so the internet works. If I connect the nest to the wall modem then it needs log in details which don't work or they just won't provide. If Google nest pro had dhcp61 it wouldn't be a issue after some researching
03-18-2023 06:36 PM - edited 03-21-2023 07:59 PM
Hello again Rgm700,
Please try the steps below:
Let us know how it goes.
Abi
03-21-2023 07:59 PM
Hi Rgm700,
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Abi
03-22-2023 11:04 PM - edited 03-25-2023 10:46 PM
Hey Rgm700,
Abi
