01-31-2024 12:26 AM
Hello I am having an issue with adding my new nest audio, to my google home
My set up is, a pixel 6, a nest wifi pro and a nest audio, so yes I like google products
I got a nest audio, activated it via the device utility app, then started to add it my google home. The installation worked up to the end until the app said that
I have one wifi network, so they are in the same network and both devices can be found in my wifi pro
But my phone can't find nest audio
I have tested every post, guide, video I found
UPnP is enabled, I have pin the IPs but no luck
My phone is on 6Ghz and nest audio is on 5GHz
What is the problem?
Thanks
