Can not reset Nest Yale lock
Ngoc
I cannot reset Google Nest Yale, I tried following Nest's instructions.
Does anyone have the same problem as me?
gmelanymelissa
Hi @Ngoc,
Thanks for posting here in the community. I'm sorry to hear you can't reset your Nest x Yale Lock. I'm happy to help!
To better understand the situation, I'd like to ask a few questions:
  • Could you describe the specific steps you took to perform the factory reset?
  • When did the inconvenience start?
  • Is the keypad illuminated?
In the meantime, let's check this tip:
  • Official Guide: Ensure you're following the exact steps outlined in the official Nest × Yale Lock reset instructions. Refer to this article: Factory reset the Nest × Yale Lock.
Keep me posted.
Melany
fanflair
The QR code inside my Yale lock goes to a random calculator website. I've had the lock for 5 years and have only had 1 or 2 issues but not this. The passcode just suddenly stopped working for no reason. The b batteries are good. The Google Connect plug is fine - green light in the test. How am I supposed to access? If the rear door lock wasn't working I'd be completely locked out of my office.
Hi @fanflair,
Thank you for reaching out to the community. I'm sorry to hear the QR code on your Nest x Yale Lock is redirecting to an unexpected website and the passcode stopped working suddenly. Help's here!
Have a look at this guide:
Let me know how it goes.
Melany
