10-08-2021 03:02 PM
Hi, I'm having trouble adding guest codes. They add perfectly in the Nest app but don't seem to take to the Yale lock. At first, neither lock was working. I removed the code and tried again which resulted in one lock working, and finally created a new user with a new code which did the trick. Just wondering if anyone has any tips to make sure in the future it works. As I use this for giving friends access it gives me pause to think the codes won't take.
10-20-2021 01:14 PM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
10-25-2021 01:08 PM
10-26-2021 04:05 PM
Hey Folks.
