04-12-2023 07:47 AM
My Nest Yale Lock worked fine for about 6 months, then it went offline.
Changed batteries - Nothing.
Moved the mini Connect closer to the lock. Nothing.
Reset the lock. Nothing.
Error keeps popping up "Something went wrong T026(4060)
The only reason I went with the Yale lock was so I could update passcodes remotely, and now that isn't an option until this thing gets back online.
Was there an updated code or firmware that got pushed out recently?
04-12-2023 05:27 PM
Hey Rmacgeorge, same issue here. Have tried factory reset a number of times with no luck. Lights cycle blue, green, red and then stays there for over 5 minutes.
04-17-2023 05:45 PM
I’m sorry to hear that and for the delayed response here. No worries, we’ll check this out — a few questions: what’s the status light of your Nest Connect? How far is your Nest x Yale Lock and Connect from the router? Are the batteries of your lock fresh and standard AA alkaline batteries? Also, what Wi-Fi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Here are some troubleshooting steps you can try:
Let me know how it goes.
04-22-2023 12:15 PM
Princess
04-23-2023 03:36 PM
Thanks for chiming in, Princess.
